3CX iOS App Won’t Connect
Pk2CA
SOHO User
We have a 3CX hosted service with users using iOS and Android apps. My iOS 3CX will not dial or receive calls. The phone dialed shows “Connecting”. I can see other users listed, with their current status. I can access and listen to voicemail. I simply can’t make calls.
I have tried:
Power cycle iPhone
Delete 3CX app on iPhone
Reprovision 3CX app on iPhone
Software updated on iPhone to 16.3 (beta)
My business partner‘s instance of 3CX on his iPhone is working fine. Any suggestions?
Are you using a VPN?
Yes! That was it, thank you! Turned it off and the app works fine. Is there a way for the app to work with a VPN or do I just need to make sure I don’t use it?
Hello, I have a similar issue with the Android app. it just says "Connecting" I have allowed all required ports. With no luck still
We do not use any VPNs, The firewall Test has a few fails as follows: The rest of the ports passed besides the BELOW
  • resolving 'sip-alg-detector.3cx.com'... done
  • testing 3CX PhoneSystem 01 SIP Server... failed (How to resolve?)
    • stopping service... done
    • detecting SIP ALG... not detected
    • testing port 5060... Mapping does not match 5060. Mapping is 9118. (How to resolve?)
    • starting service... done
  • testing 3CX PhoneSystem Media Server... failed (How to resolve?)
    • testing port 5090... done
    • testing ports [9000..9398]... failed (How to resolve?)
      • testing port 9118... Mapping does not match 9118. Mapping is 9119. (How to resolve?)
Finatra.us
