3cx is down
DennisMurithi
Getting
took too long to respond
Try:
  • Checking the connection
  • Checking the proxy and the firewall
  • Running Windows Network Diagnostics
ERR_CONNECTION_TIMED_OUT
Need more info
hosted in the cloud
3cx hosted
self hosted on our server - Debian or windows
Hi @Saqqara - sorry hosted on the cloud. I currently have 2 agents in the queue which has not "kicked" them out so they are still making/recieving calls.
My immediate vendor is uncreachable.
Unless you have access to the cloud management console , or have access to the 3cx via ssh there is not much you can do until you contact your supplier
Unable to reach management console to check/restart services. As well as access to the 3cx via ssh.
Let me keep trying the vendor.
Thank You.
So if they are making/receiving calls then 3CX is not down, just access to the management console. If the instance is under your name/company then you can try reaching out to 3CX hosting support:
If it's in your partners name you are SOL.
aatroxadrian
