Solved 3CX License Key
Marko Guarapo
I just installed elastix on a PC in order to use it as our IP PBX.
As soon as i get into the web management interface it asks for a license key. I filled up the form to get the license key at least 10 times with different email addresses and no email is received.
Please help me
I checked spam folder on all emails and went thru both websites.
Definitly both websites have issues with the zip code camp on the form because i managed to get the email by using US Zip Code. Previously i was using a Venezuelan Zip Code
Sorry for my bad english
The zip code portion is VERY Tricky.
hi @Marko Guarapo ,
Venezuela must be (pre)selected as a country and then you should enter a local Zip or Area code. You must select a result from the dropdown that you get.
