Solved 3cx lience questions
tspjoker
SOHO User
when i look at the portal for 3cx it shows
Subscription expires in: 355 days
Hosting expires in: 51 days
and it said to renew the hosted by 3cx for 1 year??
and shows me the price of 150n dollars Canadian? so is this price for license and hosting combined?? or it just hosted side of price then how my supposed to renew the license part???
i already look at 3cx price for hosted side, but it still confused me
Hi @tspjoker
The price you are seeing is for the hosting renewal for one year.
Reactions: StavrosA_3CX
Hello @tspjoker,
As soon as you get a new Key you have 2 months of free Hosting and then it expires.
Please note that this price is to renew your Hosting for another year.
Your License Key type or period want be affected.
Detailed information on Pricing you can find here.
so it's sound like a license key for subscriptions and hosted for require another key???
i'm very confused now.. so then when my liencse key got expire? then where should i renew it then?
Hello @tspjoker,
Let's clear things up,
Your License Key will expire on September 6th of 2023. In a year from now.
Your Free Hosting with 3CX will expire on the 6th of November 2022.
You can:
a) purchase Hosting through your 3CX portal before that date (6th of November 2022) for 150 dollars and keep your instance Hosted with 3CX for another year (until 6th of November 2023). License Key will be the same 4SC Standard.
b) You can let the Hosting expire and Select Self Hosting or an on Premises Installation. License will be the same 4SC Standard but No Hosting with 3CX.
c) You can upgrade to a Pro or Enterprise version of 3CX and buy Hosting. Again you can do this through your portal . You will have to pay for the License Upgrade and the Hosting with 3CX solution. (2 separate charges are summed - check the Pricing)
d) or last, upgrade to a Pro or Enterprise version of 3CX without adding the Hosting option. You can Self Host the instance yourself as with the option b) - pay only for the license upgrade .
I hope this helps.
If you have further questions or issues you can always open a support ticket.
