3CX Local RPS
vbreyter
SOHO User
I am unclear how the new 3CX RPS option under Admin -> Phones -> Options works.
1734543886434-png.45713
My understanding of RPS is that when a phone is provisioned in 3CX, 3CX then adds an entry for that phones MAX on the RPS server of the phones manufacturer. When that phone boots, it "phones home" to the manufacturer's RPS server, received the entry that 3CX added, and proceeds to download the configuration file.
This 3CX docs page seem to indicate that the new 3CX RPS feature works on the local lan. However, how doe that happen if the phone is trying to contact it's manufacturer's RPS server.
Turning off RPS - using Local IP​
By default the V20 setup provisions phones securely on the local LAN via RPS and publishes provisioning information to the 3CX RPS server. If you don’t want to use RPS, you can switch off RPS by going to Phones > Options
Turning this off means you'll provision your phones by other means, in your case - manually.
Reactions: PaulC_3CX
Also, you could use this for Local devices as well. The local provisioning link will be sent to the RPS, so it provisions automatically without you needing to select it from the Phones page and assigning it to a user.
So any phone whether it is local or remote can be provisioned through the RPS. Just trying to make it easier for you all to provision phones!
Graham Robertson
