3CX MS Teams Sync not working
rickyhorne
Hi all.
Our 3CX Teams Sync is not working as the title suggests. Wodering if I share the SupportInfo logs with anyone you could have a look at the logs to see why?
We are running version Version 20.0 Update 5 (Build 551 Release) and have enabled 2 way sync between 3CX > Teams and Teams > 3CX. There is no issue with syncing status between 3CX > Teams. This works perfectly, but we cannot sync status between Teams > 3CX, this just does not work.
All photos attached show the setup on 3CX Teams Integration.
We're only syncing specific users from M365, all of which are enabled and active in out Tenant. I have removed some old disabled accounts from syning as the 3cxManagementConsole.log file i saw this log:
2025/04/17 13:31:25.814|0037|Warn| [_3CX.Integration.Presence.Microsoft365PresenceSubscribeJob] Subscribe job failed: Account not found
However it still doesn't sync the status so I must be missing some other setting.
I would rather not share the logs publicly so If anyone from support would be interested in having a look, then I will share them over DM.
Thanks,
James
Hello James,
Can you please try to reauthorize the integration by pressing the Authorize button from Admin >> Users >> MS365 and if the issue persists can you please dm me the logs
Hello James,
Thanks for the suggestion. We are aiming to reauth the integration today and will report back.
Thanks,
James
Did you resolve this? I am having the same issue.
Thanks.
Simon
Hi, IliasL_3CX
Apologies for the delayed response.
Reauthorizing the integration has fixed the issue.
Thank you for your suggestion!
This seems to have worked for me too!
I had to delete the app on MS Entra also to make sure it was a completely new connection.
It seems to be working again.
Stephan Eusebe
