3cx not intregrate popup contact to zendesk.
ittssupport
Hi every body and support 3cx.
Plase help me 3cx not intregrate popup contact to zendesk.
My 3CX pro license can not intregrate popup contact to zendesk.
How I config and fix this problem.
3CX Version Number 15.5.0
What's parameter for fill in client secret on 3cx client ?
How I wrong config ?
I try test to Insightly crm it's normal.
Thank you very much.
Hello @ittssupport,
You're configuring the client and the server side integration. Please note that the client side integration has been deprecated, you should use the server side approach as described here:
https://www.3cx.com/docs/zendesk-crm-integration/
As per the screenshots you sent, this is properly configured. But maybe you don't know how this works. Let me explain:
- When an inbound call arrives, the contact will be taken from Zendesk and imported into 3CX Contacts.
- The contact name will be shown as the caller name, no matter the phone you use.
- If you use the 3CX Web Client, a button to open the contact record will also be shown.
So, please ensure that you're using the 3CX Web Client when you receive the inbound call.
Kind regards.
johnkerr995
