3CX on Blackberry
Shelin
Is anyone using 3CX on blackberry? Could you kindly provide some info on how to install?
are they still a thing?!
The last Blackberry is from 2018 an Android phone. I am really sure this wont work with 3cx.
Although the 3cx app can be installed and all the functions seem to be normal, it can dial in and out, but there is a serious problem.
The BlackBerry has all the relevant settings and permissions, but the microphone can't output sound (with other apps it is normal, e.g. Line), only 3cx's sound output is not normal.
So wanted to ask if anyone here has also encountered this problem and solution?:oops:
Which Blackberry Phone is it? If its the last from 2018 i am sure it wont work. If its older we dont need to talk about that.
This device is on Android 8... maybe it could work because 3cx App on Android should work from version 8. But if you cant get it working in some minutes, i would spend any time in this old device anymore.
Got it! Thank you so much!
Carlos - EC Mates
