3CX on cloud is missing generic sip trunk options?
harryyeung1999
SMB User
I have only seen 3CX tested option only, but where is the generic one?
@harryyeung1999
With SMB you can use only providers that are available within the system.
Generic providers are not supported and therefore can be used only with a dedicated systems.
i remember that is available previously, is that a new policy to restrict it?
SMB always required use of tested supported providers available to choose in the system.
My friend just share with me, he can create generic sip trunk in smb on cloud version
what's different causing my smb doesn't have it?
We both have limitation of 10 users and also on cloud version, so that's make me believe we are all in same SMB system
is your friend's system web client finishes with xxxx.3cx.cloud? or something else?
yes
Yes, just different number to me
xxxx.3cx.cloud
yes
xxxx.3cx.cloud
I have tested SMB by signing up for one just now and confirm that only 3CX Supported providers can be used.
