3CX on Windows? Domain-joined or not?
Frank86
When setting up 3CX on a Windows PC/server, is it better if the machine is on the domain or not? Or does it make no difference either way?
We set ours up in a workgroup, as the system does not need to authenicate against the domain.
I suggest putting it in a network DMZ zone and not on your domain. Typically you want any public facing servers segmented from the rest of your internal network.
Reactions: Frank86
The two aren't mutually exclusive.
It's simple really. You should follow the principle of least permission.
fransisco
