3cx Outbound dialer failing to send calls out. Am testing with the demo template. But i adjusted it to fix my environment
mjafari
08/22/2023 9:01:22 PM - SendMsg from "deno test"<sip:[email protected]:5060>;tag=7d127913 to <sip:[email protected]>;tag=c209525c
08/22/2023 9:01:22 PM - MakeCall request is sent to 111
08/22/2023 9:01:22 PM - CA request makeCall(dn_from=, number_to=, handler=111)
08/22/2023 9:01:22 PM - L:14.1[Extn:102] Sending: OnSendResp Send 180/INVITE from 0.0.0.0:0 tid=Pjab7c51d8e2374956a3e07d7b584f3f96 Call-ID=13bc380f185f4fde83dece9840aa2f5b:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 192.168.100.185:60295;rport=60295;branch=z9hG4bKPjab7c51d8e2374956a3e07d7b584f3f96
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]>;tag=b0280c6b
From: <sip:[email protected]>;tag=65b2ed2cba0647fc9d32d90e56453f55
Call-ID: 13bc380f185f4fde83dece9840aa2f5b
CSeq: 1333 INVITE
Content-Length: 0
08/22/2023 9:01:22 PM - SendMsg from <sip:[email protected]>;tag=b0280c6b to <sip:[email protected]>;tag=65b2ed2cba0647fc9d32d90e56453f55
08/22/2023 9:01:22 PM - L:14.2[Unk?:111] got Provisional Recv 180/INVITE from 127.0.0.1:5483 tid=5374915f84254f3d Call-ID=u5elwuAuvJ9YoNVe7w7c2Q..:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 127.0.0.1:5060;branch=z9hG4bK-524287-1---5374915f84254f3d;rport=5060
Contact: <sip:[email protected]:5483;rinstance=0e52f126ad1a67d1>
To: <sip:[email protected]>;tag=c209525c
From: "deno test"<sip:[email protected]:5060>;tag=7d127913
Call-ID: u5elwuAuvJ9YoNVe7w7c2Q..
CSeq: 1 INVITE
User-Agent: 3CX RoutePoint
Content-Length: 0
08/22/2023 9:01:22 PM - Provisional(180) from <sip:[email protected]>;tag=c209525c to "deno test"<sip:[email protected]:5060>;tag=7d127913
08/22/2023 9:01:22 PM - [CM505001]: Endpoint Unk?:111: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX RoutePoint] PBX contact: [sip:[email protected]:5060]
08/22/2023 9:01:22 PM - [CM503002]: Call(C:14): Alerting Unk?:111 by contact <sip:[email protected]:5483/UDP>
08/22/2023 9:01:22 PM - Answer from <sip:[email protected]>;tag=c209525c to "deno test"<sip:[email protected]:5060>;tag=7d127913
08/22/2023 9:01:22 PM - [CM503025]: Call(C:14): Calling T:Unk?:111@[Dev:sip:[email protected]:5483;rinstance=0e52f126ad1a67d1] for L:14.1[Extn:102]
08/22/2023 9:01:22 PM - Route to L:14.2[Unk?:111] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=5374915f84254f3d Call-ID=u5elwuAuvJ9YoNVe7w7c2Q..:
INVITE sip:[email protected]:5483;rinstance=0e52f126ad1a67d1 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---5374915f84254f3d;rport
Max-Forwards: 70
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
Content-Type: application/sdp
Supported: replaces, timer
Content-Length: 350
v=0
o=3cxPS 15602810880 141079609345 IN IP4 127.0.0.1
s=3cxPS Audio call
c=IN IP4 127.0.0.1
b=AS:84
t=0 0
a=X-nat:0
m=audio 7048 RTP/AVP 8 0 101
c=IN IP4 127.0.0.1
b=TIAS:64000
a=sendrecv
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ssrc:1699769700 cname:7ba642c360be6a82
a=rtcp:7049
08/22/2023 9:01:22 PM - SLA is globally disabled
08/22/2023 9:01:22 PM - Added leg L:14.2[Unk?:111] <-> L:14.1[Extn:102]
08/22/2023 9:01:22 PM - [Flow] Call(C:14): making call from L:14.1[Extn:102] to T:Unk?:111@[Dev:sip:[email protected]:5483;rinstance=0e52f126ad1a67d1]
08/22/2023 9:01:22 PM - [CM503027]: Call(C:14): From: Extn:102 (<sip:[email protected]:0>) to T:Unk?:111@[Dev:sip:[email protected]:5483;rinstance=0e52f126ad1a67d1]
08/22/2023 9:01:22 PM - [CM503004]: Call(C:14): Route 1: from L:14.1[Extn:102] to T:Unk?:111@[Dev:sip:[email protected]:5483;rinstance=0e52f126ad1a67d1]
08/22/2023 9:01:22 PM - [Flow] Endpoint Unk?:111 has no forwarding rule on reason 'All calls'
08/22/2023 9:01:22 PM - [Flow] Call(C:14): has built target endpoint: Unk?:111 for call from L:14.1[Extn:102]
08/22/2023 9:01:22 PM - [Flow] Target endpoint for 111 is Unk?:111
08/22/2023 9:01:22 PM - [Flow] Building target endpoint to 111 from <sip:[email protected]:0>
08/22/2023 9:01:22 PM - [CM503010]: Call(C:14): Making route(s) from Extn:102 to <sip:[email protected]:0/UDP>
08/22/2023 9:01:22 PM - Remote SDP is set for leg L:14.1[Extn:102]
08/22/2023 9:01:22 PM - [CM505001]: Endpoint Extn:102: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [MicroSIP/3.21.3] PBX contact: [sip:[email protected]:5060]
08/22/2023 9:01:22 PM - Inbound DID: ''; Phonebook Name: ''
Exactly what trunk are you attempting to send 111 to?
ARKC
