3CX paging to multiple public address zones
Mark Phillips
Does anyone have experience of using 3CX in a public building where public announcement messages are broadcast over the PA system by the user dialling a paging extension and making the announcement via their VoIP telephone?
I'm looking at 4 separate PA zones, each with its own amplifier. Therefore I think I'd need four Snom PA1 or similar.
Then, thinking about paging from 3CX, is it possible to set up various groups, so that I could page the following combinations of zones?
All Zones - 1,2,3,4
Lower Ground Floor Zones - 1, 2
First Floor Zones - 3, 4
Staff Areas only - 2,3
Public Areas only -1,4
Mark
I am using a Bogen TAMB2 that was already here
https://www.bogen.com/products/pdfs/telephonepagepdfs/TAMB2m.pdf
with a GrandStream HT801
http://www.grandstream.com/products/gateways-and-atas/analog-telephone-adaptors/product/ht801
to accomplish something similar. The Bogen provides the nice beginning tone that alerts a page is coming. In 3CX the HT801 is fully supported and is a simple extension, so a call to the PA extension will results in an alert tone followed by the message. In your case you would have four extensions and then wrap them in whatever ring-groups you need.The Bogen has some interesting configuration options such as background music; it's a very solid piece of equipment.
Hi Mark,
The PA1 is end of life (but still works for now). The Fanvil PA2 and iW30 are in the supported models.
You can set up paging numbers and include the devices you want accordingly (from the ring groups section).
11921
Interesting - so you just set the HT801 to auto answer and then the TAMB2 detects the off hook and springs to life?
Any disadvantages to this over using the paging facility?
Exactly, the HT801 is just a simple 3CX extension so it just "answers" the phone as any normal deskphone. There was one setting in the HT801 that needed to be set to tell the Bogen to hang up when the call/page was completed. It was really a 5 minute setup with the HT801 and 3CX built-in support. The Bogen handles the initial audible tone before the page, and it's been a fine solution. In your case, just wrap a few of these extensions around a ring group when you want more than one. In your case the HT814 might work perfectly, although I'm not familiar with how the four ports are addressed.
Any other experiences out there?
Reactions: Mark Phillips
Reactions: qbitnetworking
bosdorf
