3CX password
satman1w
I have some version od 3CX installed on Raspberry Pi. It was installed long time ago and password is forgotten.
I have root access and I am sure that the password can be edited / erased somewhere in file system but... where...
Any help would be appreciated
ok, thanks for taking time to answer...
The first two links does not load anything.
Third says:
Step 1
Create a 3CX Backup using the 3CX Backup and Restore Tool and save to your desktop.
This will output the backup to a compressed ZIP File
Unzip the backup file and open the contents.
How am I suppose to make backup if I cannot login to PBX, it is a question...
regards
Try this: https://www.3cx.com/docs/backup-restore-command-line/, you only need the configuration backed up.
I would, though, recommend that after you have managed to gain access to the management console, take a complete backup and move the system to 3cx hosted. The Pis are no longer supported for the 3cx phone system, only for the 3cx SBC, so you can use them to install the 3cx SBC to connect to the 3cx hosted system and provision IP phones.
I suppose that it was assumed that once you had done any changes/configuration, you would have done a back-up, in the event you needed to restore, saving yourself some grief if there was a failure.
Reactions: satman1w
:-D of course... there was nothing to backup at the time so, no, I dont have one!
@Charles_3CX Can you have someone look into the help.3cx.com site?
On-premises*
  • Sad
Reactions: SteveITS
Hi, I’m afraid it’s been taken down, we don’t have any information whether it will be back.
Sad. It had a lot of useful articles like Hosted limitations. I hope you get it back up.
mazet
