3CX PHONE NOT REGISTER
Jonathanlarose
I try to test 3CX, but my Polycom vvx300 don't working. I see on phone line unregister!
0921085111|clist|4|00|dbDirSet::saveEntry:Invalid contact!!!. Contact is not stored into database ...
0921085113|app1 |*|00|[AppHybridC]: App is completely initialized.
0921085113|so |4|00|[SoNcasC]: appncascontext termination:1
0921085113|so |4|00|[SoNcasC]: Case Handling termination:1
0921085113|cfg |5|00|Prm|Parameter reg.x.outboundProxy.port requested type 0 but is of type 2
0921085113|sip |*|00|Sip Register Usr:8225 Dsp:Daniel Rocheleau Auth:'yG42ANyftP' Inx:0
0921085113|utilm|4|00|uBLFUnCompressed: File /ffs0/Config/Local/WebTicket/0/sip.usr doesn't exist or is empty
0921085113|sip |*|00|Fast Boot Measurement Point: Ready for Call, uptime: 73.916 sec.
0921085113|app1 |4|00|Corporate directory is not Enabled.
0921085113|clist|4|00|dbCfg::getServerDir:Unknown dbCfg type
0921085113|moh |*|00|Initial log entry. Current logging level 4
0921085113|moh |4|00|SoNcasMohC::soNcasmohCfgInit: File provisioning for Music On Hold is defined only for Lync Profile and if Music On Hold feature is enabled
0921085113|cfg |*|00|Prov|Starting to provision
0921085113|cfg |5|00|Prov|cfgProvStatusSet: Unknown status 53
0921085113|cfg |*|00|Prov|Starting to update 3111-46135-002.sip.ld
0921085113|copy |*|00|Server '192.168.0.40' said 'provisioning/ovpvtg1v81/3111-46135-002.sip.ld' is not present
0921085113|cfg |*|00|Prov|Starting to update sip.ld
0921085113|copy |*|00|Server '192.168.0.40' said 'provisioning/ovpvtg1v81/sip.ld' is not present
0921085113|copy |*|00|Server '192.168.0.40' said 'provisioning/ovpvtg1v81/0004f26b0c0b-phone.cfg' is not present
0921085113|cfg |4|00|Prov|File transfer failed due to curl error code:22 and respCode:404
0921085113|copy |*|00|Server '192.168.0.40' said 'provisioning/ovpvtg1v81/0004f26b0c0b-web.cfg' is not present
0921085113|copy |*|00|Server '192.168.0.40' said 'provisioning/ovpvtg1v81/000000000000-license.cfg' is not present
0921085113|copy |*|00|Server '192.168.0.40' said 'provisioning/ovpvtg1v81/0004f26b0c0b-license.cfg' is not present
0921085113|cfg |*|00|Prov|Setting device parameters from configuration files.
0921085113|cfg |4|00|RT|cfgFlashUpdateFromConfig: Failed to update SerialConfig
0921085114|cfg |*|00|Prov|Finished updating configuration
ourladyofguadalupeamarill
