3CX PhoneSystem 01 SIP Server Stopped
acontreras
Error:
Stopped
This is the second week we have this error, restarting the service fix the issue
I'm not sure what to look. My extensions are 3 digits, when I go to Activity Log I can see extensions with 4 digits.
Can this error be caused by a trunk timeout error?
EXTRA INFO:
3CX Version, e.g. Standard Annual 16.0.2.910
Standard Annual 16.0.5.619
Server OS, e.g. Debian 9 / Windows Server 2012 R2 / Raspberry Pi
Debian 9 strech
4 GB RAM, 2 vCPUs, 80 GB SSD
Is the 3CX Server Hosted and where?
Amazon Lightsail
IP Phone Make/Model/Firmware
Granstream GXP2140, 2160, 2130, 2135 firmware 1.0.11.6
Thanks!!
Provisioning Method: Local / VPN / STUN / SBC
SBC
Trunk Provider or Gateway Make/Model
Telnyx
Has the Firewall Checker passed: YES / NO
YES
Are custom Phone Templates being used: YES / NO
NO
How much disk space is free?
Is this a build from the Debian ISO?
Are you running anything else on the VM?
you would need to put PBX in to versbose logging and replicate the issue to check a service not starting issue.
We have 70 gb free, only 11% it’s used.
this instance was created using PBX Express, we didn’t select the ISO
We don’t know how to replicate this issue, we just know is second time we get this error.
if we put the PBX in versbose will this affect any feature or functionality?
thanks for the assistance
You will have to reboot the PBX to apply logging level.
You're not really supposed to leave it running as it uses some resource but theres no harm really if you check your resource level and set it to purge logs every 2 days or something.
Reactions: acontreras
The 4 digit "extensions" are your SIP trunks. Since it is your Sip Server crashing I would suspect the trunk error may be the problem. I would try deleteing the trunks and re-installing. If problem persists do as kieferschild said and use verbose logging to help resolve the issue
bosdorf
