- Joined
- Sep 11, 2023
- Messages
- 368
- Reaction score
- 47
I have a 3CX v20 PBX updated from V18. Version 20.0 Update 2 (Build 715 Release) On Premise. After the update I can't configure the voip trunk with certified partner TWT unless using generic voip template, if I use voip provider it goes into unregistered error. I tried to install a clean test V20 and on that I can register the trunk with twt template with the same parameters. Also having trunks with other 3CX PBXs if I change some settings of a trunk on the Master the PBX in question. suddenly all the bridge trunks with other PBXs go into unregistered error if I go to the slaves error trunk 127.0.0.1 port 5080 sip:127.0.0.1:5080;lr) is not reachable, DNS error resolving FQDN, or service is not available. Entering the slaves I move the trunk temporarily on the 5060 it goes up the answer on the 5090 everything goes back to working perfectly.
