3cx Raspberry PI
Craigboy442
Forum User
Running into an issue where we are attempting to install 3cx onto our Raspberry PI 3 B+ model using the instructions here https://www.3cx.com/docs/installing-pbx-raspberry-pi/
Here is the error I am getting.
sudo apt -t stable install 3cxpbx
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
3cxpbx : Depends: libicu57 but it is not installable
Depends: libcurl3 (>= 7.52.1) but it is not installable
E: Unable to correct problems, you have held broken packages.
Has anyone else run into this issue?
What version of Raspian are you using? 3CX only supports Stretch-based Debian at the moment.
[email protected].
