Solved 3CX recording via email
siscom
Good Morning Colleagues
I hope you are doing good and safe.
May i know if 3CX supports sending email to Queue manager including the recording for each call once the call end ?
Best Regards
Reactions: siscom
Hi @siscom,
As @leejor very rightly said, not this isn't available natively. The only emails queue managers get can be seen in the Queue >> Notifications >> Queue Email Notifications.
Note that: Group members with the right "Can see group recordings (Available in Professional and Enterprise)" will be able to see the group recordings.
His link may provide a solution for you.
Reactions: siscom
Hi @siscom,
Thx for your feedback
As far as I'm aware, any third party application, for 3CX, will not be a "free" option. You'd have to contact the company, that provided the information about their solution, in that thread.
You could use the report feature or the Webclient to get an easy access to recordings.
Using reports, they would get a list of calls with the recording link in it.
Thx Leejor
Thx Frederick
Sure thing @siscom, if you require any further assistance, feel free to open a new thread.
Thx Vasilis
Reactions: VasilisV_3CX
devo.it
