Solved 3CX - Report language changed after upgrade
Slowpoke_sama
Forum User
Hello.
I've recently upgraded from v14 to v15.5.
3CX is installed on a Windows machine with native language Formats and Location.
Language for non-Unicode programs is set to English.
When we had v14 installed all call reports were in english.
After v15.5 upgrade all call reports are in native language.
Regional settings have not changed since v14 was installed.
Question - how can i receive call reports in english with minimum effort?
Okay, trying to answer my own question.
Changing regional settings to English did not help.
Reports are still created in native language.
How can this be cured?
Rebooting after the regional change did not help too.
Windows was installed in US version.
Okay. Found out the problem.
To those who face this on windows server 2012 r2.
If you want your reports to be displayed in english (instead of your country native language)- log in to the machine tat has 3CX installed>go to Control panel>Language> Set settings like those in attachment > reboot> try to generate reports.
This should probably work for other languages too.
Thanks 3CX forum, you helped a lot :D
Glad to see the issue has been resolved and thank you for updating the thread with your solution.
Bluebox Global
