3cx sbc ssl ceritifcation error
gtcldn
I have been trying to switch my on perm pbx over to digitalOcean, which seems to work but i can only THEN access it via ip address. When i have it on perm i can only access it via FQDN.
So i created a dns lookupzone and added hosts but for some reason it STILL doesn't work but i at least am able to access it even if it's only through ip when going to cloud. ANYWAYS
I switched it over to cloud host and i can not get SBC installed, i keep getting this SSL error, i have looked through forums and i haven't been able to get this to work.
I was able to create a SBC a couple of months ago no problem but now i seem to be having issues.
3cx must have a valid secure SSL certificate so if you have a custom certificate which has expired or not renewed, the installation will fail. Now the SSL cerfiticate renewed about a week ago, so i don't understand whats going on.
What type of license is it? Pro has a 6 hour TTL.
Can you browse to the hosted server from that location? It sounds like you can’t so is the hostname resolving correctly?
The system should be accessible with the FQDN now, Did you try it, does it work for you?
There may have been a delay in the DNS propagation from whichever DNS servers you are using from the time you switched off the old instance to starting the services in the DO instance. On our side, this was pretty instant.
Reactions: IrinaP_3CX
yes its pro, and when i switched it over to vm on digitalOcean i was able to access it via IP-which is fine but i could not get SBC going because of SSL certificate
i ended up up going back to on prem. since i couldn't get sbc to work and phones wouldn't work.
Note the popup message says, "also" it needs a certificate. It sounds to me like the hostname hadn't updated to the new IP yet so just couldn't connect and was showing a general "can't connect" message. Setting up a local zone to point to the new IP, on the DNS server the SBC was set to use, could override that.
Reactions: Charles_3CX
i did add it to dns but i will try again
mazet
