3CX SBC Update BETA Including Debian 13 Support
AndreasY_3CX
Staff member
Performance and stability upgrades, component updates and a new base OS.​
Keeping SBCs secure and up to date is essential for maintaining reliable connectivity between remote IP phones and your 3CX system. This update brings you refreshed components, several stability improvements, and introduces automatic Linux OS updates.
Upgraded ours without issue via the script. For anyone wondering, the script does also install the update for the SBC software, in addition to the OS upgrade.
I got a stupid question:
To install the HA SBC, we need a clean Debian 12/13 install, correct? If that's the case, any current HA setup will need to be reinstalled, as the script to upgrade won't work as it won't find the marker for the 3CX ISO?
Correct me if I am wrong.
With 3CX still being Debian 12, will there be a separate ISO for Debian 13 with this new SBC?
When I check the box to update and then click download, the check box get unmarked and does not update? Am I doing something wrong?
Hi, if you look at the requirements in the blog post:
  • The system is running Debian 12 (Bookworm).
Since your SBC is V18 it's probably running on Deb 10 (or even Deb 9).
The official downloadable ISO will be updated when the new SBC is no longer a BETA.
I see, you still using the list format for apt. Will you switch to the Debian 13 standard format DEB822?
Reactions: fxbastler
If the HA setup was done using 3CX ISOs, then you should be able to update/upgrade normally via the PBX UI. The 3CX ISO supports the HA install directly and the marker would be there.
Note that , it would be best/recommended if you first did an UPDATE (first of the one SBC, and then the second one when it takes over), and then as a separate step the OS UPGRADE, again one at a time.
So just to be clear... if you're using a Raspberry Pi as an SBC, we should prepare a new SD card and not use the "Download" option on the System > Updates page? Also, it says the software is BETA... so we can skip that and wait for a full release?
This is the first time the System > Updates page has shown any updates available.
Hello @guzzitech ,
This is indeed a beta release, so you can choose to install or not as you see fit.
Regarding Raspberry Pi 5, the online updater will update the SBC part; if you wish to have the OS upgraded from Debian 12 to Debian 13, then you need to do the full install via SD card formatting.
But to be clear, you can't auto-update if the device is running version 18?? So then for a Pi SBC you just do the install process again to update?
Hello @guzzitech ,
If this is a Beta release of the SBC, the version 20.0.176 is what installs when setting up a new SBC on a Pi and running the script to install the SBC software.
https://www.3cx.com/docs/installing-pbx-raspberry-pi/
When running " sudo bash -c "$(wget -qO- https://downloads-global.3cx.com/downloads/sbc/3cxsbc.zip)" " it downloads version 20.0.176 and not 20.0.100 as the SBC version.
Is this supposed to happen?
If you'd rather avoid the beta version, even though it's been available for over two months, you can force the installation of version 20.0.100 with the commands below.
This will install the SBC version released in August 2024, as long as 3CX still provides it in the repository.
Just a note: Don't use version 20.0.100 on Debian 13.
Bash:
printf 'Package: 3cxsbc\nPin: version 20.0.100\nPin-Priority: 1001\n' | sudo tee /etc/apt/preferences.d/3cxsbc >/dev/null
Install the SBC normally:
Bash:
Then remove the pin so future updates aren't blocked:
Bash:
sudo rm -f /etc/apt/preferences.d/3cxsbc
Personally, even though 20.0.176 is still marked as beta, I wouldn't be too concerned about running the latest SBC version in production. Unlike the 3CX PBX itself, the SBC is a much simpler component with a more limited role.
That's just my personal opinion.
amazingbv
