3CX Send Fax
Bitblade
Fax to email is supported with 3CX as standard, however if you want the use of a Fax machine to send Fax's then you will need to purchase an FXS gateway - here is the supported list: https://www.3cx.com/voip-gateways/
I would recommend Patton for quality, and Grandstream for price.
Hello @Bitblade
As mentioned to send FAX through 3CX you will need an FXS Gateway and a FAX machine. You will also need a provider that supports T.38 so i would recommend going for a supported provider.
https://www.3cx.com/partners/sip-trunks/
ok, thanks so far, i misunderstood the customer, he wants to send faxes from computers, not from a fax machine. if i read this correctly https://www.goldbolt.com/ from edi-kojsi should bring the solution.
megalmazan
