3cx Services not starting automatically upon system restart.
Zaffar Rasheed
After restarting the system all the services for the 3cx not starting, I am using Windows 10 64 bit. following type of error seen in the event log for all the services.
The 3CX PhoneSystem 01 System Server service depends on the 3CX PhoneSystem 01 Configuration Server service which failed to start because of the following error:
The operation completed successfully.
Are you able to start the services manually after the server reboot ?
Can you change the startup of '3CX PhoneSystem 01 System Server' to Automatic (Delay Start) to see if this helps
Yes I am able to start it manually.
Do you want to change it to Automatic Delay Start?
How do your services startup options look like?
Normally they would appear as such on a healthy system:
12127
Except one or two of 3cx status shows nothing and the startup type is Automatic only
Is it a new PBX install or was it running properly and suddenly it doesn't start anymore?
Which windows 10 do you use V1903 ? is it a Pro 64 version ?
If it shows no Status, it is not running. Can you attempt to start them all one by one (the ones that are not running)?
Also what hardware is this running on? Is there a chance the disk access it too slow that the services fail due to timeout?
Its Windows 10 Pro 64
Its i3 PC
Hi Zaffar,
Please try to add delayed start then on all services to give the machine a chance to boot up and idle a bit. If you can start them manually then there is no problem generally speaking and this method may help you.
[email protected].
