3CX SIP server fails on two openvpn connections
Yaroslav
Hello!
I made two VPN connection (to office and to my cloud VPN server) and SIP Server stopped:
Code:
Sep 28 21:40:43 3cx kernel: [204081.612307] 3CXPhoneSystem[14736]: segfault at 0 ip 0000000000519e9b sp 00007f1284fa23d0 error 4 in 3CXPhoneSystem[400000+3d2000]
Here is some info
Code:
root@3cx:~# service 3CXPhoneSystem01 status
● 3CXPhoneSystem01.service - 3CX PhoneSystem 01 SIP Server
   Loaded: loaded (/lib/systemd/system/3CXPhoneSystem01.service; enabled; vendor preset: enabled)
   Active: failed (Result: signal) since Fri 2018-09-28 21:40:43 MSK; 1s ago
  Process: 14810 ExecStopPost=/bin/rm -f /var/run/phonesystem/3CXPhoneSystem01.pid (code=exited, status=0/SUCCESS)
  Process: 14721 ExecStart=/usr/sbin/3CXPhoneSystem -p /var/run/phonesystem/3CXPhoneSystem01.pid /var/lib/3cxpbx/Instance1/Bin/3CXPho
neSystem.ini (code=killed, signal=SEGV)
 Main PID: 14721 (code=killed, signal=SEGV)
Sep 28 21:39:36 3cx systemd[1]: Starting 3CX PhoneSystem 01 SIP Server...
Sep 28 21:39:37 3cx systemd[1]: Started 3CX PhoneSystem 01 SIP Server.
Sep 28 21:40:43 3cx systemd[1]: 3CXPhoneSystem01.service: Main process exited, code=killed, status=11/SEGV
Sep 28 21:40:43 3cx systemd[1]: 3CXPhoneSystem01.service: Unit entered failed state.
Sep 28 21:40:43 3cx systemd[1]: 3CXPhoneSystem01.service: Failed with result 'signal'.
root@3cx:~# ps aux | grep openvpn
root     14795  0.0  0.6  41968  6720 pts/2    S    21:40   0:00 openvpn --route-noexec --config cloudVPN-direct.ovpn
root     14850  0.0  0.0  12756   996 pts/2    S+   21:41   0:00 grep openvpn
root     21265  0.0  0.5  42252  5900 ?        Ss   10:00   0:08 openvpn --config work.ovpn
This is problem config:
Code:
client
remote X.X.X.X 636
proto tcp
dev tun
cipher AES-256-CBC
auth SHA256
resolv-retry infinite
nobind
persist-key
persist-tun
remote-cert-tls server
verify-x509-name chunk-note-giant name
tls-version-min 1.2
compress
verb 3
route X.X.X.X 255.255.255.255 net_gateway
<ca>
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
</ca>
<cert>
</cert>
<key>
-----BEGIN RSA PRIVATE KEY-----
-----END RSA PRIVATE KEY-----
</key>
<tls-crypt>
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
-----END OpenVPN Static key V1-----
</tls-crypt>
Can you please help me to debug and fix this issue?
My 3CX host OS id Debian 9 and 3CX PBX version is 15.5.0 beta
Why are you using open VPN ? This is an un-supported setup.
Where I have known people to use Open VPN without issue, I would say why bother when you have supported methods of STUN and SBC you can use.
Guides clearly state no VPN on the PBX. Not going to find much help here.
Hello @Yaroslav
As mentioned you should not run a VPN software on the 3CX server as this could cause issues like the one you are experiencing. The VPN should be done on your firewall/router, not on the PBX.
fngl
