3CX SMS Integration
Nik_si
when I trying to POST from terminal, it's successfully received to client, but client is not able to reply me, also web manager shows me erros, from webhook.
curl https://next.sms.myphone.ge/api/v1/messages \
-H "Authorization: Bearer Bearer Token" \
-d "content=message content1." \
-d "from=LLC Fixit" \
-d "to=9955XXXXXX"
how is it works, if the sms provider is 3rd party and not partner of 3cx?
does someone knows what kind of Json format is supported by 3CX to avoid this message?
Event ID : 30045
Unable to parse message from provider generic. Error: Unknown message received: { "status": "delivered", "id": "mes_P7p9QY2m6YB4j", "description": "Status updated to delivered" }
p.s I successfully Integrate Generic SMS provider, If someone wants guide, reply.
Event ID : 30045
Literally 3 posts above: https://www.3cx.com/community/goto/post?id=638347
rsaldin@advancedbrainspin
