3cx softphone dialing issue
razortas
Intermediate Cert.
Hi im running Deb version 16 and am attempting to use 3cx softphone - registered to 3cx. Can call extensions, incoming calls working however any calls outgoing attempted are in Activity Log states _ failed to create outbound lines to call #Number#. And when making subsequent calls the number is appending to the number called and then it fails to find number.
To get it back to being able to dial i have to go into configuration and change SIP port back and forth so that it re-registers.
Outbound Rule is simply "calls to number prefix 0" Discard numbers =1 .
3CX softphone version is 6.0.26523.0 and yes i have one outbound rule as above
prefix 0 to get line and discard that when making the call - dailing entire number including country code etc.
Do outbound calls for other extensions (not 3CX Softphone) work? When you review a failed call in the Activity Log what does the number look like, that is being matched to the outbound rule(s)? What does your outbound rule look like?
Please uninstall your softphone, that is a very old version that is no longer being maintained.
Install the latest version from here https://www.3cx.com/user-manual/
3K8iMGWviZ
