You don't need to uncheck the " Disallow use of extension outside the LAN " option. The app uses the remote tunnel to connect.Don't forget to allow extensions to be used out of LAN in options restrictions
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
