- Joined
- Jan 31, 2023
- Messages
- 6
- Reaction score
- 0
Looks like you're SQL query is wrong. It should start with "select", but in your case it starts enumerating the table columns... You should run your query using MySQL Workbench before, so you're sure that the query works as you need.thank you for the reply, but the DB structure is created by step by step guide.
https://www.3cx.com/docs/sql-database-pbx-integration/
i'm stuck on point 3 i dont know how 3cx want sql table
Enter the Lookup By Number SQL Statement. This will be used when doing the lookup for calls or chat interactions through SMS. This must be a SELECT statement returning the following case-sensitive columns:
contactid, firstname, lastname, companyname, email, phonemobile, phonemobile2, phonehome, phonehome2, phonebusiness, phonebusiness2, phoneother, faxbusiness, faxhome, pager, photourl.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
