Solved 3CX SSL Domain Certificate not auto renewing
rr_john
Hi Team,
I'm having some issues with an SSL Certificate auto renewing on a 3CX hosted domain name. I've tried the usual with rebooting the server and forcing a manual SSL Update using the renew command
/usr/lib/3cxpbx/PbxConfigTool -renew-certificates
When checking the logs i get the following error indicating the renewal is failing
2022/02/06 04:24:04 [error] 563#563: OCSP response not successful (6: unauthorized) while requesting certificate status, responder: r3.o.lencr.org, peer: 96.16.55.78:80, certificate: "/var/lib/3cxpbx/Bin/nginx/conf/Instance1/*****.co.3cx.us-crt.pem"
2022/02/06 04:29:43 [error] 563#563: OCSP response not successful (6: unauthorized) while requesting certificate status, responder: r3.o.lencr.org, peer: 96.16.55.78:80, certificate: "/var/lib/3cxpbx/Bin/nginx/conf/Instance1//*****.co.3cx.us-crt.pem"
2022/02/06 04:34:57 [error] 563#563: OCSP response not successful (6: unauthorized) while requesting certificate status, responder: r3.o.lencr.org, peer: 96.16.55.78:80, certificate: "/var/lib/3cxpbx/Bin/nginx/conf/Instance1//*****.co.3cx.us-crt.pem"
2022/02/06 04:39:58 [error] 563#563: OCSP response not successful (6: unauthorized) while requesting certificate status, responder: r3.o.lencr.org, peer: 96.16.55.78:80, certificate: "/var/lib/3cxpbx/Bin/nginx/conf/Instance1//*****.co.3cx.us-crt.pem"
2022/02/06 04:45:22 [error] 563#563: OCSP response not successful (6: unauthorized) while requesting certificate status, responder: r3.o.lencr.org, peer: 96.16.55.78:80, certificate: "/var/lib/3cxpbx/Bin/nginx/conf/Instance1//*****.co.3cx.us-crt.pem"
2022/02/06 04:50:34 [error] 563#563: OCSP response not successful (6: unauthorized) while requesting certificate status, responder: r3.o.lencr.org, peer: 96.16.55.78:80, certificate: "/var/lib/3cxpbx/Bin/nginx/conf/Instance1//*****.co.3cx.us-crt.pem"
2022/02/06 04:55:43 [error] 563#563: OCSP response not successful (6: unauthorized) while requesting certificate status, responder: r3.o.lencr.org, peer: 96.16.55.78:80, certificate: "/var/lib/3cxpbx/Bin/nginx/conf/Instance1//*****.co.3cx.us-crt.pem"
Does anyone have a solution to this? Its been down for over a week now and i can only access the portal using chrome and bypassing the certificate.
Thanks in advance
John K
What version of 3CX and where is 3CX installed?
Hi Cobaltit,
Latest version V18 with all updates installed, installed on AWS instance, self managed with 3CX FQDN.
John
@rr_john
Simply running the command is not enough, can you confirm if the SSL certificate has already expired or is close to expiring? Also, if it has expired and not renewed automatically yet, is this not the first time this happened for this instance?
Brilliant!
Do feel free to start a new thread should you need anything else!
Bluebox Global
