Solved 3CX SSL Renewal Failed
Harry Torres
Hello. Got an email this morning about SSL Renewal Fail for one of my clients. Google Cloud hosted version 16.0.1581:
HTTPS Certificate renewal Failed - Error:
IpUpdater.FqdnGenerationException: Error creating FQDN: Unexpected error : {
"type": "urn:acme:error:badNonce",
"detail": "JWS has invalid anti-replay nonce o74X-pX3ao64REXfdjUS6bE30UPEdtz7M_0594E7qns",
"status": 400
} ; LetsEncrypt: The remote server returned an error: (400) Bad Request.
at PostInstall.CertificateHelper.ProcessCertificatesDirectory(String directory, Boolean temporaryCertificateGenerated, Int32 regenerateNotSelfSignedCertificatesFrom, Int32 regenerateNotSelfSignedCertificatesTo, CloudServerStatus statuses, Int32 regenerateCertificateExiredInDays, String appBin, UInt16 sipPort, UInt16 tunnelPort, Boolean isPassiveFailoverMode)
at PostInstall.CertificateHelper.RenewCertificates(String appBin, String nginxConfigFolder, String configurationPath)
Is there a way to manually fix it? I'm trying to avoid down time.
Thanks.
Do you have current maintenance on this PBX?
Yes, until license renewal, then it renews again. 3CX is up to date.
So unless it's been failing for weeks you should be good. There should be plenty of time until the cert actually expires and it only tries once a day.
You are right!! Thank you so much for this information. It tried again overnight and succeeded.
Reactions: YiannisH_3CX
devo.it
