3cx stuck on Version 20.0 Update 7 (Build 1080 Release)?
J_Finalattempt
3cx states its upto date. Have restarted the box and services, No change. tied turn off and on automatic updates. Any suggestion on how to manually get the update done?
Can you access the machine via SSH, run "apt-cache policy 3cxpbx ", and send us a screenshot of the output?
Hi Charles,
thanks for coming back to me. Please find the attached.
@J_Finalattempt can you please try one more time and let us know ?
Try " apt update " ( this will not trigger the update, it trigger the check ) and let us know if you see the update on the PBX side.
Hi, I can now see the 20.0 Update 8. I will get that installed out of hours and about update 9 tomorrow.
amazingbv
