3CX support NUMA?
ITSmartwork
i have a 3CX latest version on prem installation running on Proxmox 8.1.8.
This VM has 12GB of RAM and the hotplug(on Options) was enabled for Memory and CPU and thus NUMA was needed to be enabled at CPU config so that the machine could run. Everything was running normally, until i recieved a notification that the server had killed the main process of the 3CX due to out of memory.
As you can see the anomaly is that the 3CX itself has recognizing only 895MB of RAM.
i disabled the hotplug for memory and cpu, than i disabled the numa and the VM now see 11.8 GB which is fine.
Does the debian version used in 3CX support NUMA?
Carlos - EC Mates
