3CX Supported USB Handset
Kwang Mien
Gold Partner
May I know if there is any USB Handset which is supported by 3CX ?
Thanks.
Regards,
Kwang Mien
I am looking for a Handset that is connected by USB to Laptop or PCs. The user will talk through the handset.
Not something I'm aware of.
Could they not just have a USB headset or a bluetooth ear piece?
Regardless, you'll be using the 3CX softphone with it.
Any supported operating system usb headset will work with 3CX
their requirement is to have USB handset.
@Kwang Mien
If the OS picks it up, the drivers are in order, and therefore the microphone and speaker can be identified as two separate devices on the OS level, then it should work just fine. I do however recommend maybe testing one thoroughly before committing to a obtaining a large number of them just to be sure.
Grandstream GUV3000/3005
Jabra
Poly
EPOS
There are many choices of good headsets.
Did a quick Google search and came up with one on Amazon for about $60. Unfortunately, unless these are made for a specific application, like Skype (with extra features that are probably not going to function with 3CX), there is probably not a big demand for a USB handset, as opposed to a much more convenient to use, headset. I have seen suggestions, that a check with an Asian equivalent of Amazon, may provide some options.
As suggested, buy one and test it, as the quality of some of these, may be as low as the price.
Thanks for the suggestion. I was wondering if there is any 3CX recommended USB Handset brands.
@Kwang Mien
Can i know if 3CX recommends any brand of USB handsets that works well with 3CX ?
I am actually looking for USB handsets.
Oh, handsets... good luck! And no 3CX does not have any recommendations for this specific type of device.
Tech_Support
