3CX Supported Wireless WiFi VoIP Phones?
Edward_Fitzgerald
Need some recommendations on wireless WiFi VoIP phones that are supported with 3CX. Can't seem to find any and I though I'd check if you guys could help me out. Thanks
There are none right now. However, the Grandstream WP820 works great with 3CX from what I've heard.
Reactions: Edward_Fitzgerald
Have you used it before?
If you did, what template did you use? I'm guessing that one of the other Grandstream templates should work, but I could be wrong.
I've never used the WP820 but I use many Grandstream devices with 3CX.
As for the template, no, others won't work. If you are a Grandstream partner, you can request a template from GS directly but note that it won't be supported by 3CX. I use custom templates for GXV3370 and DP752 and they work beautifully.
DM me for more info on GS templates.
I was able to provision a Wp820 using the standard Grandstream 3cx template. The only problem i have noticed is when the phone loses a wifi connection during a call, 3cx doesn't always release the call.
I'm supposedly on the grandstream waiting list for their wp820 template but haven't heard anything in 6 months or more.
What template did you use? Those included in 3CX are using P-codes and are NOT COMPATIBLE with other models. You might be lucky for a few P-codes but mostly they differ from model to model.
As for the template from GS, if you are a partner of them, simply open a new ticket and directly ask for it, they might be kind enough to send it to you but 3CX will not support it, only Grandstream will.
I don't know if someone from 3CX can tell us, but I think they are working on certifying a few new devices from GS, it might just take some time since it's a long process of back-and-forth.
It would have been the same GS 3CX template asnused by the GXP1782 phone.
Trust me, all I did was edit the template to include the name WP820 - I did not change any P codes.
The WP820 registers, makes, receives, transfers calls and even roams between wifi access points. There may be some advanced features that don't work but I haven't found any yet.
That's what I said, you're lucky.
Obviously, the best thing is to use a template made for the phone. Some features or settings are tweaked from device to device. Even the 3CX official template has if/else statement for different models of phones.
Lucky, maybe.
I'm just stating that it is possible to easily get the WP820 working the standard Grandstream 3CX template, even though the phone isn't officially supported. You also stated that it wasn't possible with the standard 3CX template - so I corrected you. :)
Lucky, maybe.
I never tested it and would never have. I have some experience with Grandstream devices and I've learn the hard way that "it just works" is not always the case ;)
I was wrong, but I don't think anyone would recommend doing this over using an officially GS-provided template for each device.
If they were using simpler config (instead of annoying P-codes) like Yealink and Cisco, obviously, It'd be different.
My favourite Wifi desk set is also, unfortunately, no longer officially supported...the Cisco SPA525G. For a single set or two, it's great, as it is easily configured with a GUI, especially if you are familiar with any Linksys/Cisco menu. They are relatively easy to find and (usually) at a good price. If you're not doing a whole office, they are worth keeping an eye out for.
So it depends on what you consider supported. All of the T4X phones support WiFi with the add-on dongle, but the wifi itself has to be configured manually, it's not configurable in the management console. Snom D3XX and D7XX phones also have a wifi dongle. And are you sure you want WiFi? DECT is almost universally better if you don't have a proper wireless network.
[email protected].
