3cx Timezone & Office Hours Settings Bug
Justin Estruch
I'm not sure if this is a bug or an intended design but when editing the global office hours ( settings > Timezone, Office Hours & Holidays ) let's say for Monday they are currently set for 09:00 - 18:00, if you click on that a window opens up that allows you to change the time but that "Ok" button is always greyed out. I believe the Ok button should not be greyed out and you should be allowed to save the new configured times. The only way that I know of that will allow you to change the times is to first deleted the configured time and then configure a new one. Again I'm not sure if this is an intended design or a bug but thought I should report this as it seems it can be an easy fix and confuses some customers who think it's a permission issue or something else. I've added some screenshots below.
Thanks,
Justin
PBX Version: 16.0.8.9
OS: linuxScreen Shot 2021-06-07 at 10.18.40 AM.png
@Justin Estruch,
Thank you for bringing this to our attention, we're well aware of this. While I wouldn't call it a bug, it is an inconvenience which will be addressed sooner or later. For now you'll have to delete it and add it with the time you'd like.
BIT Incorporated
