3cx Twilio SMS one way
VH IT
I have followed the documentation on configuring for voice and SMS for Twilio.
-I can create a message in my 3cx chat and send an SMS to a phone number. (twilio message log shows outgoing API delivered)
-I create a message in my 3cx chat and send SMS to phone number with picture jpeg attached (twilio message shows outgoing API failed with media) and I get the message:
(Error:11200) HTTP retrieval failure
Twilio's servers were unable to fetch a non-error response from the designated URL
-if I send a SMS to my 3cx DID (just text or an image) it shows on the twilio messaging log that it was received by messaging service and that it was delivered but I never get it in my 3cx chat.
This is the only DID I have on my extension. Things basically work one way (out to a cell number, but only text works) yet the twilio side is showing that it has no problems delivering the sms into 3cx but I never get it.
No idea for twilio but we see a good some of customers with issues that are configuration related with our SMS/MMS integration on 3CX.
Most common:
1. Check that your numbers are in E164 format, for example: +15553331234
2. Make sure the SMS is routed to an extension or group, if IVR make sure its is forwarded: https://voxtelesys.com/tutorial/3cx-sms-setup-with-an-ivr
3. Firewall checker Passes?
Not as common but still an issue:
1. Check you webhook URL is correct, make sure it is an FQDN and not an IP
2. Does your domain have valid certs? Also have to check intermediate certs https://www.3cx.com/community/threads/unable-to-get-incoming-sms-voxtelesys.121587/#post-569140
If it is only MMS that is failing then maybe make sure MMS is enabled/supported on the provider.
Reactions: Nathan@Voxtelesys
j.hereijgers
