Solved 3CX Updates Page Not Showing V16
Chris Hackett
I thought it was out already? My updates page isn't showing the newest version. Does anyone know when will this show?
Cheers
Chris
v16 will show in Linux builds but not in Windows.
you have to remove v15 and install v16.
Hi Chris,
Remember to make a full 3CX backup and take it out of the default folder as it will be deleted when you uninstall V15. Once that's done, you can install V16 and restore from your backup.
Thanks for your replies, I guess as it's a major update it doesn't show in the updates like minor updates do.
Cheers
Chris
GP Concepts
