3CX updates
NashP
After the recent update on PBX which was installed on 02/09.
We are having issues of one way audio for many systems.
Is anyone else having same problems? Recommendations?
Also does V15 has install updates automatically option?
No problems here:
As far as the updates question, I think this on the Updates page is pretty clear:
Thanks for the information. We have a PBX on Version 15 but I don't see any option for automatic updates. When I browse to Updates pade it just has list of updates available. I assume automatic update feature was not available in version 15? I can see it in 15.5
Sorry I didn't realize you were talking about two separate PBXs or versions. Yes 'Automatic Updates' was added in v15.5 which you will need to upgrade to very soon per the 3CX announcement regarding the activation server changes (again).
Hello @Nash Patel
Can you please let us know the exact version of the PBX you are running? You can see the exact build number on the Dashboard, under the Information column next to the licence version. For example 15.5.15502.6.
Hi YiannisH,
It is version 15 so that sums up I guess.
If you are running the latest version then as a first step i would recommend running the firewall checker and see if you pass all the tests
megalmazan
