- Joined
- Apr 25, 2012
- Messages
- 27
- Reaction score
- 0
Upgraded last night from V15.5 to V16.0. on Windows Server 2016. Took a very long time to backup and restore, but it did work. All yealink phones needed to be updated with latest firmware, they would/will not upgrade via the 3CX console. I ended up updating them manually (100+ phones), hopefully that won't be the case next time, I've never had this issue before.I read and understood the issues and limitations with CFD not being fully implemented, based on what I read seemed like I would be okay with my very simple CFD. After the upgrade, our old CFD was no longer working, it's just a simple date time condition that should work. I opened the old CFD in the new call flow designer application, everything looks good, resaved. However, I have nowhere to update the CFD in V16. I know I need Beta to have the call flow apps under advanced.... It's not clear to me why the old CFD doesn't work in the first place as the documentation indicates most existing CFD's will work without modification.
