3CX use with Vitleity
sns0227
Hello. I'm new and a 3CX layperson. Can anyone tell me if I'm able to configure 3CX with my VoIP provider - Vitelity.com ? I do not see them on the list of SIP trunk Providers. Does anyone know of an inexpensive route to help me configure my Vitelity DID with 3CX? Thanks in advance - SNS
Hi @sns0227 Vitelity sip trunks can be used only with dedicated installations and not with Free/SMB.
You may find more info here.
Does this mean I would need my own dedicated server to install 3CX? Do you know of any providers that offer this service with 3cx ready to be used with Vitelity? Thank you!
If you want to the Free/SMB versions, then you need to use the providers that are available in the list.
But if you still want to use the Vitelity sip trunk, then it means you need a dedicated installation, for example using Hosted by 3CX, Self Hosted or On Premise.
Where can I find Hosted by 3cx? Thanks for all your help
You have to access to the customer portal and go to my systems ---- add a new system and select Hosted by 3CX.
Also you may find a 3CX partner in your area using this link.
Reactions: IrinaP_3CX
RJenkinsROCK
