3CX V.16 and Grandstream GXW4104
dhellenbart
Hi to all
I have implemented 3cx with analog gateway GXW4104 to pstn
Inbound rules working perfect but i can not solved outboudn calls.
When i make calls to outside this is outcome
09/14/2019 9:32:48 PM - [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 192.168.1.50:5060 tid=6a3911122aab8f02 Call-ID=8ObmUU-yKcZf3_WswEy1eQ..:
INVITE sip:[email protected]:5060;transport=udp;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.1.50:5060;branch=z9hG4bK-524287-1---6a3911122aab8f02;rport=5060
Max-Forwards: 70
Contact: <sip:192.168.1.50:5060>
To: <sip:[email protected]:5060;transport=udp;user=phone>
From: "RECEPCIJA"<sip:192.168.1.50:5060;transport=udp;user=phone>;tag=ec54f941
Call-ID: 8ObmUU-yKcZf3_WswEy1eQ..
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
Content-Type: application/sdp
Proxy-Authorization: Digest username="10000",realm="3CXPhoneSystem",nonce="414d53595d7d406045:db24edfa59b9ff6815dd3d5b2ae68e9b",uri="sip:[email protected]:5060;transport=udp;user=phone",response="ad1722e8d65872e7357d704cd98ff407",algorithm=MD5
Supported: replaces, timer
Content-Length: 288
v=0
o=3cxPS 29569551226109952 15915077131567105 IN IP4 192.168.1.50
s=3cxPS Audio call
c=IN IP4 192.168.1.50
t=0 0
m=audio 7038 RTP/AVP 0 8 9 3 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=rtpmap:3 GSM/8000
a=rtpmap:101 telephone-event/8000
a=sendrecv
Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
Alongside the above, also check the gateway firmware as this can have an effect on the template used, some vendors ship devices with firmware which is vastly out of date.
Solver...provisioning problem
bosdorf
