3CX V15
NeedNova2
New User
Hello, where can i get a 3CX V15 License key, now you might be wondering, why am I wanting to use 3CX v15? Because I would like to use v18-unsupported cisco phones (preferably the 7961) if anyone can help thank you.
But it only says for v15 and older?
They are tested with v15 SP1 and not exactly something that 3CX continues to test, but should still work with v18 on prem installations.
Okay good, on prem means on premasis right? I have my computer here with it installed.
Alright good, do I need to make an XML file for it or no?
I don't think you will need to, but you will need to add custom templates to 3CX. I've attached the 2 you will need.
Thank you very much
GCLANtech
