3CX v16 Database query status EXT
Riccardo M.
Good morning,
we are trying to put 3CX (ver.16) under monitoring on Zabbix and we would need to know how, via query, contact the DB and get the info for EXT and its status.
We found this post link but the structure is from 15.5. link
Can anyone give us a hand? thank you
Accessing the 3CX database, is not allowed - if you do managed it you will not be supported by 3CX
I know that.
we need just make a query and reply that on Zabbix, but to make that we need to know what are the tables dedicated tothe status of EXT
Since, as @Saqqara mentioned, accessing the 3CX Database is strongly NOT recommended and WILL render the 3CX Instance in question an unsupported configuration I'd suggest looking into other ways of achieving this.
That said you might want to check out the 3CX CFD and the Get Extension Status component. If you need information beyond what's available in our docs or assistance please feel free to start a thread in our forum's CFD section: https://www.3cx.com/community/forums/call-flow-designer.63/
Silent_Guru
