- Joined
- Mar 26, 2015
- Messages
- 16
- Reaction score
- 5
After updating to version 16 from 15 we've had a few issues. One issue is with routing the calls either through the SIP Trunks section or Inbound Rules section. For example one of our tenants had their calls set to go to a Ring Group in the SIP Trunk section. I created an IVR and then set the calls to go to the IVR but they continue ringing to the Ring Group. I tried setting the calls to go to an outside number, voicemail of an extension, even just to end the call. Nothing works, the calls keep ringing through to the Ring Group. Similar issue with Inbound Rules. I'll create a rule for a certain number but the call isn't following that rule. The call will only do what was set in the SIP Trunk section from before. Not sure what's going on. Also, now for Android phones the Push isn't working to wake up the phone when there's a call coming in. Tried deleting the app and reinstalling it, sending a new Welcome Email to provision it but still nothing. So any kind of change I try to make to the call routing isn't working and not sure if that's what may be causing the issue with the app. Does anyone have any ideas on what may be causing this?
