3CX V18 client with more profiles
bit101
Hi togheter,
in the new Windows client V18 i cannot find the possibility to provisioning more than 1 extension.
So in the V16 Windows client and also in the smartphone apps i can add/provisioning more that 1 extension profile.
How it is possible in the V18 Windows client?
regards
Unfortunately, this is not possible due to the way the desktop app provisions, which requires the webclient to open on the extension than from the Windows or Mac icon, when clicked on, reveals the pop-up to provision the desktop app. Each desktop app can only be provisioned with one extension at a time and there is no option to switch profiles other than to open the WebClient for the extension required and provision it using the method above.
Can someone make this a feature request in the Ideas section?
The Desktop App doesn't support more than one account. I don't know if it's in Ideas but it's been brought up several times here since the release of v18 and doesn't seem likely to change. The advice I've seen from 3CX is to use different Windows profiles, or sign into the web client.
megalmazan
