Solved 3CX v18 Debian - Twilio - inbound MMS not working
snydertech
I upgraded to v18 for nothing else then the MMS support. Everything went smooth with the upgrade, however I can't receive MMS messages.I can send and receive SMS just fine, nothing has changed there. I can even send MMS messages so long as I keep the message under 1MB limit but I can't receive any MMS to 3CX. Even the Twilio dashboard says the message was successfully delivered to the 3CX api but I never receive it to my extension. The api message test succeeds too. So I'm not sure if I'm doing something wrong or maybe this feature is just half baked at the moment..? Any Ideas?
Plz upgrade the webhook URL in twillio to support MMS
Thank you, I went back and looked at section 7 of the sms/mms configuration within 3cx and at first I didn't see anything different in the URL then I noticed it said V3 instead of V1 which is what I still had in the Twilio webhook. Honestly if it wasn't for you mentioning that I probably would have never checked because regular SMS was still flowing and MMS was going out.
I do notice though that the images that are coming in show up with some weird trans-coated file name and you have to double click it to download it and it doesn't show up natively in the timeline like the outgoing images do.
I'm sure that functionality might be coming at a later time (hopefully) but either way it's working now so thank you!
Reactions: NickD_3CX
j.hereijgers
