3CX v20 – Call Flow Designer Apps not visible in Admin Console
Dimos82
Trial User
I am running 3CX v20.0 Update 8 (Build 1109) on a trial (Professional) license.
Although I can build CFD projects successfully with the Call Flow Designer tool (ZIP generated without errors), I cannot find any way to deploy or manage Call Flow Apps in the Admin Console.
Specifically:
  • No Call Flow Apps menu under Advanced or System
  • No User / Extension type = Call Flow App
  • No upload or deploy option anywhere in the UI
I have checked Advanced, System, Users, Extensions, Call Handling and Digital Receptionist, and I am logged in as System Owner.
Question: Is Call Flow Designer deployment intentionally removed or deprecated in v20, or am I missing a specific menu or configuration step?
Thanks in advance for a clarification.
Integrations > Call Scripts
I'm not sure if this option is available in trials.... Maybe you need to convert it to a paid customer. If it's available, it should be where @ConceptsWeb just pointed out.
Thank you both! Yeah, i found! I hope the systems lets me upload the .zip when i purchase the licence.
Yes. The feature is simply blocked during trials. When ready, feel free to reach out for the license if you wish to have a partner to assist!
ARKC
