3CX V20 Importing call route
vsquare
Platinum Partner
I know in v20 update 5, the ability to import call routes with naming was added. In v18, I typically export the current list of ICRs, clear it out and add the new lines. Then import the file.
My question, is there a way to export the ICR's to get a CSV compatible with the import function, or is there a template CSV available somewhere to utilize this?
Create a CSV file where the first column are the DIDs, the 2nd is the destination number like user extension, queue number, and the third column is for the DID name. Then save the file as comma separated values and import it in the sip trunk ---- DIDs tab.
Have a good day!
dominik.pepel
