donbru01 Premier Customer Joined Nov 30, 2011 Messages 141 Reaction score 0 Nov 10, 2025 #1 I have extension 1152 registered , that is showed green , but is showed red in Tel IP . Extension work fine , but how isn't show tel ip? i attach some snap shot Attachments 1a.png 4.3 KB · Views: 17 1b.png 5.9 KB · Views: 17
KyriacosS_3CX Staff member Joined May 8, 2025 Messages 2,398 Reaction score 2,024 Nov 11, 2025 #2 Is the phone/device working OK? Is it using the standard template and connected directly or via an SMB?
JohnS_3CX Support Team Staff member 3CX Support Joined Jan 4, 2019 Messages 14,577 Reaction score 3,752 Nov 11, 2025 #3 Hi, This is expected because you are using an unsupported device. Your screenshot shows you've provisioned a PA3, but you're actually using some other model that 3CX does not know. Reactions: KyriacosS_3CX
donbru01 Premier Customer Joined Nov 30, 2011 Messages 141 Reaction score 0 Nov 11, 2025 #4 strange i have a lot of device unsupported also PA3 but no issue see snapshot Attachments 3a.png 119.6 KB · Views: 6 4a.png 112.1 KB · Views: 6
bitn2 3CX MVP Platinum Partner Advanced Certified Joined Mar 25, 2020 Messages 2,707 Reaction score 1,608 Nov 11, 2025 #5 If you provision an PA3 and actually using something different than you are on your own to configure this stuff. Thats not supported.
