3CX v20 - Manage Prompts
Eureka
Hi there,
Where can I mamnage the prompts in v20 please ? I cannot find.
For example to listen to a prompt while settings up a holiday.
Best,
J.
System > MOH
Your prompts will be available in your drop downs when in call handling.
Sorry but.... How can I listen to a prompt on a physical phone, as before on v18 ?
You cant, you can only record from your phone.
If you want to listen to voicemail prompts you can dial the voicemail menu.
Tanks for your help, so sad to loose nice features like this.
NB: Another way to listen the prompts is to go on the local files of the server.
Best,
J.
Or just download it to your computer and listen to it.
Graham Robertson
